I live in a 4 bedroom house (3 bed upstairs, lounge+kitchen+bed downstairs). It needs rewiring so I planned to run the upstairs off one ring main, downstairs off a second ring main and the kitchen off a third ring main (obviously the cooker on its own 32a radial). I haven't been in this line of work professionally for 8 years now so I've lost touch with the latest wiring regulations.
Perhaps the main issue is the fact that such work is notifiable and if you intend to do the work yourself you must speak to your Local Authority Building Control before you start any work.
You cannot do the work yourself and then get a registered electrician in to test alone, he/she will have to have been involved in the whole process from the beginning.
I was chatting to a sparky the other day who's currently working on some new houses. He said radial circuits are starting to come back in as the prefered method as opposed to a ring main and I should be using radial's all through my house. What do you guys think?
I don't think radial final circuits ever went out of fashion.
As has already been stated work out your demand and design your circuits accordingly - with redundancy in mind.
I completed a rewire a few months ago on a two storey four bedroom property which had two individual radial final circuits for the bedroom and landing sockets. Each circuit was protected by its own 20Amp RCBO.
Three double sockets per bedroom and one for the landing. The circuit design and bedroom layout allowed each bedroom to have at least two sockets on different radials.
Electric shower on its own radial.
Downstairs the kitchen was on its own ring final circuit with individual radials for the oven/cooker and the fridge/freezer.
The two downstairs rooms each had their own 20Amp radials but with sockets shared in a similar way to the bedrooms.
Three lighting circuits - for the front of the house rooms, the rear of the house rooms, the outside security lights and the mains/battery smoke alarms circuit.
I also added several other specific circuits.
All circuits RCBO protected on a fourteen way board.
This particular house and the expected demand lent itself to this approach. Each property will be different.
