Hi - I want to replace a double light switch. The new switch has COM, L1, L2 connections in two separate blocks. The old switch has the same, and for one block there are wires in all three, for the other block there is only COM and L1. I tried to replace with the new switch using the same wiring pattern but it trips the electric fuses, I put the old switch back on and all works fine. Have I done something stupid or is the switch faulty?
Similarly, I want to replace a single light switch, it only has two wires and two connections on the switch itself, how do I wire up a new switch with three connections?
Many thanks
Many thanks
