Rewiring - plastering advice
2 Nov 2004
We will soon get our house rewired and will end up with lots of "chasing out" to fill up.
Should I use "patching plaster" - which I have used before and found to dry very soft and flaky - or should I mix some real plaster?
Hi Brett
In my opinion its best to fill the chases with bonding first and then apply a finish plaster coat feathered in to the existing plaster finish each side of the chase. Hope this helps.
Andy
Brett
I would agree with Andy, remember to leave the bonding plaster a little lower so that you have room to put the finishing plaster on this way you can taper it like Andy suggest. I have used patching plaster in the past and really don't rate it
