Good morning!
Hoping you guys can help me. I am going to be installing 3 No. 5m LED RGB (7.2W/m) strip lights in a ceiling trough. The strip lights will be powered by a 120W transformer hidden in the trough and I'm planning on controlling the lights via a LED wifi controller (also hidden in the trough) wired between the transformer and the lights. A couple of questions;
1. What is the best way to connect this to the main lighting circuit? I assume I can just run the supply from an existing ceiling light in the room, and therefore be controlled by the existing switch on the wall?
2. If the above is an acceptable solution, would you expect the LED wifi controller to be constantly be switched on and off? I would therefore expect a short lag period between the wifi controller starting up and connecting to my phone before I can control them?
3. I assume it is possible to connect the 3 No. LED strips to the single supply from the Wifi controller via a junction box?
P.S: This is the Wifi controller I plan to use: https://www.led-lighthouse.co.uk/le...roller-for-strip-lighting-android-iphone-ipad
Thanks in advance.
Chris
Thanks in advance.
Chris
