I have one of the above with an 11 HP Briggs & Stratton engine. Went to use it today & round a large pool of oil under it, leaking from the exhaust. Found that the sump was full of a mixture of oil & petrol so I took the head off but could not see anything wrong with valves or piston although the mixture was leaking past the exhaust valve ( partly open where it had stopped). The only thing I can think of is that the float in the carb stuck open & gravity let the fuel leak through the carb into the sump. Stripped & cleaned float & chamber (was a few bits of crap in it ), drained sump & refilled with oil.It started as soon as I cranked it over I guess because there was a little fuel left in carb. Have ordered a fuel tap for future use but wondered if anyone knew of any other reason for this problem. Thanks.
