Ridge tile repair
14 Sep 2013
Nottinghamshire
Hi all, had a few ridge tiles blow off on our house and so I dont overpay, what sort of cost should i be looking at to remove, reseat with new cement and replace missing ridge tiles on the run pictured? Local roofer who gets good reviews has just quoted around £800 plus about £250 for scaffolding.
I am a new member and trying to post a new thread about my ridge tile broken but I can't find the post button.. Any idea why I can't post. Thanks
Near the top of this page, click on "Roofing and Guttering," that should take you to the start of the section. Then look for an orange box "start new thread" and click it.
To see a list of all sections, click on "forums."
Read the first one at the top for an example
To attract the attention of a member, type the at sign @
Followed by their username
Thus:
@Joanne Ledger
When you see a helpful post, hover your cursor near the bottom right of it and click "thanks."
OP,
a brief scaffold swept around the outside corner would be safe - however, that whole line of hip tiles must be lifted and re-bedded or replaced.
lifting and re-bedding might also involve changing out a number of the plain tiles.
the actual ridge line tiles on both sides of the chimney stack need examining to check how securely they are bedded-in.
in fact, it would be in your interest to have the other hip capping tiles examined as well.
and to go a little further - the flaunching on the chimney stack looks to be perished and also needs checking - go in your loft and look for water staining esp around the loft chimney breast.
and further, the left hand fascia board is rotting at the mitre corner.
and for a last further, even allowing for the projection of the bottom hip tile the corner gutter arrangement seems strange - is the gutter leaking at those fittings?
roof ladders must be used by the roofers.
