ring main connected with connector block
25 Dec 2007
Hi all,
our elec has made a fuss over a ring main connected with one of the white connectors. Is this against the regs? I think the previous owner did this because the main was too short to reach the CU.
Regards,
that depends, using terminal block is not in itself a problem. Using terminal block that is too small is a problem. Using terminal block without a suitable enclosure is a problem. Using terminal block where is can't be accessed for inspection is a problem.
there is usually no need, you can put in an extra socket instead. it might be useful.
do you mean choc block or white junction box (round about 3" diam)
mazme
