Ring or Not
14 Aug 2006
Leicestershire
Hi, just bought a house, I'm looking to extend the ring main but not 100% sure.
I have unscrewed the socket in bedroom, there are 3 wires going in, I believe that two are part of the ring main and the other I suspect is powering a fan heater in bathroom.
Would I be right in believing I have found the ring main and can go ahead.
Mike :?:
If you have found three cables, each with with wires (most likely red, black, and green&yellow sheathed copper) then you might have found a socket that is on the ring and has a spur off it.
If you have a continuity tester pt a multimeter, you can see which (if any) are the ring cables - switch off the power and verify that the circuit is dead and that your tester works, then take the wires out of the terminals of the socket and test continuity - if a ring, there should be continuity acrooss the two reds, and across the two blacks. There will not be continuity with the spur. (There must also be continuity across the earths, but there is often continuity across earths that are not part of a ring. this is normal.)
If you want to take a spur, take it from a socket that doesn't already have a spur on it.
Or enlarge the ring.
Thanks for that :D
Have a meter, will check whats what, need 2 sockets so will extend ring.
Its an old house so just needed a little reassurance before starting.
Cheers
