Speak for yourself - there's no chance of me getting tied up in knots! Moreover, since I started the topic, I believe that it's my prerogative to tie any shape or size of knot I like. If any hypothesis I present is to difficult for you, then please feel free to ignore this topic.anobium said:Softus ,I think we are all in danger of tying ourselves up in knots on this topic.
I agree that capillary action, as a manifestation of surface tension, is a natural and understood phenomenen, but I don't agree that rising damp through brickwork is. Maybe I will, in the course of reading, discussing and learning, but I haven't yet.anobium said:Firstly has I know it rising damp is a natural phenomena caused by the upward movement of moisture through certain materials by capillary action.
Please state the names of any individual and/or company, in any country, who holds this opinion, so that I can ask them why they hold it.anobium said:This is not just the opinion of the industry in this country but also the opinions of those in the USA and Australia plus also the companies who manufacture bricks.
You surpass yourself in referring to things that I haven't said in a way that would make the casual reader believe that I have said them. Please desist, as I'm starting to get fed up of correcting you.anobium said:It is not as you said caused by the failure of a damp proof course.
To re-iterate: I have never thought, let alone said or written, that rising damp is caused by the failure of a DPC. What I have said is that I would like to hear from anyone who has, and I quote, "real-life examples of rising damp caused ONLY by a failed DPC in the wall".
To put this in the terms that you appear to need in order to understand, I don't want to hear about damp where there appears to be a faultless DPC in place.
Er, no it doesn't, unless it's contiguous with the floor membrane.anobium said:The dpc merely stops it rising above a given point.
At bleeding last - now we're getting somewhere! I should be grateful if you would provide the following additional information:anobium said:I personally have seen rising damp on bare brick internal dividing walls.
How have I come to the conclusion that it was rising damp, by the following.
Firstly I examined the walls in question for the presence of any water pipe that could be causing the problem.
Normally one would check externally for possible defects, but as I said this was an internal wall so it was not necessary.
I then took samples of the brickwork and mortar joints starting from the base of the wall and then at approx every 300 mm intervals approx two thirds into the wall upto a height of 1 metre These samples were then placed in airtight bags and then sent to a laboratory with a request for them to be analysed for the total moisture content and the free moisture content.
The free moisture content is the total less the hygroscopic moisture content.
In this case the results came back showing a free moisture content of 15% at the base of the wall reducing to approximately 7% 1 metre high.
From these tests I concluded that the wall was suffering from rising damp and I recomended that a new dpc be installed.
For the record the wall eventually dried out , but not immediately as it was 325 mm thick.
1. How old was the wall?
2. What were the living conditions? E.g. centrall heated or not.
3. What type of bricks were they?
4. What type of DPC did you install?
5. How wide was the wall?
6. How long is "not immediately", to the nearest month, say?
7. Where, in the country, roughly, was/is this wall?
I have not said, on this topic, that rising damp is misdiagnosed.anobium said:I should point out that I have had cases were the hygroscopic moisture content is greater than free moisture content, and in these cases the cause of the dampness would be classed as being hygroscopic and would therefore not require a new damp proof course
I would however agree with you and many other posts on this subject that rising damp is misdiagnosed in the majority of ocassions and damp courses are inserted unnecessarily.
I didn't have any misgivings. You can take everyting I write on this topic at face value - if I was blunt or rude, then I meant to be blunt or rude. If I expressed doubt, then I was doubtful.anobium said:Hope that this goes some way to answer some of your misgivings on my previous posts
However, we have moved forward, but it's taken an awful long time, and it's beyond me to understand, from what you've written, why you have taken so long to reveal the information that has, only now, and only partially, come to light.
Please do continue to post because I want to know more.
