Robust electric shower
21 Oct 2004
Has anyone come across a shower suitable for installation in a barn, that's intended for use in washing horses and horse type paraphernalia?
The usual shiny white plastic Triton/Mira/Sadia affairs just seem the wrong thing to be using, and I can't help but wonder if there's something more 'agricultural' available.
The electrical supply is single phase 230VAC, and the water supply is up to 10bar cold (private supply from a local spring), reduced down as required.
Why not fit a BF LPG water heater up to 24 kw and give you loads of water for your horse. If using leccy to give enough flow for washing a horse it would work with two or three showers and three heads, a deffinate non starter.
Thanks for the suggestion, but the customer doesn't want the additional complication of supplying gas to the barn, even if bottled/tanked.
