Triton Enrich Electric Shower
It shouldn't be connected to the cold water storage cistern in the loft, it should be connected to the incoming cold water main.
If the shower is upstairs then I'm surprised it has worked on hi power, if located downstairs then a fair chance it would work on hi power, in the winter anyway with low water supply temp.
It's a mains shower, would it be a big deal to connect it to the mains?,
The tank temperature just now is at least 20C so running it on one element might allow it to run continuously and you will get ~ 80% of flowrate at 38/40C that you would get in winter with a 6/7C tank temp.
If you haven't already done so, clean the filter.
