Hello,
I have a leak in my ROCA Cistern which is from the seal breaking down from normal wear and tear over a number of years. I have two cisterns and this happened to both, I was able to sort out one of them with ease, however, the second one is proving to be trickier.
I have uploaded a pic to make explaining easier https://gofile.io/d/J3hR1N
1- this is where I was able to unscrew the valve for the first cistern and put it back.
2- this is where I had to unscrew the valve for the second one as the first one was stuck really tight. However, by unscrewing it here I can't seem to be able to rescrew it back into the cistern as the washer on the other side seems to have fallen off...
Because of this, there is a small trickle of water going through all the time. Is there anyway to be able to get a tight seal or do I need to remove the actual cistern of the wall to be able to screw it back on?
Thanks.
Thanks.
