Hi All
Just after a bit of advice regarding sizing before ordering a roller garage door.
For info, it will be back/behind mounted - not reveal mounted.
Height wise, no problems, however
I've measured up and found that the opening is not perfect (are they ever?). Its +/- about 10mm on the vertical on both sides. The lintel is level, the floor is level, but the sides have a bit of variation due to rough brickwork and not being perfectly plumb. Its about 10mm over 2.4m
My question is regarding the width to order. Is there any reason not to order a door that is 20mm too wide, therefore taking all of the issues out of the equation. I don't know if this will impact the operation. Otherwise I will just order as per their recommendations when I call on Monday.
Thanks in advance
Dallypro
Thanks in advance
Dallypro
