Ronseal Anti Condensation Paint?
24 Oct 2018
Hi all,
so, i'm part way through insulating the garage, now i've put in vapour membranes etc. What i'm keen to avoid is any condensation to accumulate from inside out rather than coming in from outside.
So, with this in mind, I have seen ronseal anti condensation paint.
anyone used it? any good?
just keen to keep moisture down where I can
16 Jun 2006
London
There are paints that claim to have superior thermal qualities and anti-fungicidal properties.
Personally I suspect that the thermal qualities are possibly over rated.
I don't understand why you think you will have lots of condensation generated inside the garage. If you currently have excessive moisture, you might be better off by improving airflow.
JP_
17 May 2012
If you are insulating it properly, and presumably adding some heat, then condensation shouldn't be a problem? Unless you plan to turn it into a shower room, kitchen etc.
Trickle vents?
24 Oct 2018
yeah all insulated, will certainly be adding heat - that throws a question up really, do I need constant heat? I was intending to heat as and when required, but probably best to apply a constant minimum heat I assume, just to maintain internal heat.
but no, not a shower room, not a kitchen (might stick a kettle in there mind and it does have a fridge) other than that, just a man cave
JP_
17 May 2012
Probably depends what you keep in there. Shouldn't need constant heat if well insulated with good vapour control. But if left freezing for weeks on end it will still get very cold and moisture in the air will get in somehow. Should stay dry though... You could always get one of those tube heaters with thermostat and timer to keep it from freezing.
7 Jan 2011
Warwickshire
From what I understand it has cork in it to improve its thermal properties
Didn't work in my old cold bathroom!
24 Oct 2018
fair enough, won't bother then! probably just go with some Dulux kitchen or bathroom paint in that case, least then it'll last - our bathroom one does the job well in there so should easily cope with the garage (and I have a pot left over)
