Im considering placing two doors inbetween a lounge and dining room, so I have the option of two seperated rooms. Is it worth using four doors so the whole room can be opened up, a neighbouring house has done this and seems quite effective.
Cheers, the four door option, they used a track system installed in the floor. Its obviously more exspensive but do you think its better than the two door option?
Cheers
can you not put a bigger door lining in,have you the space?then you could have 2 doors hanging on each side.
or if you have the money and time loose the doors within the wall,no doubt this is a big job.
