Hi All - I have been having issues where the heating doesent switch off when the room gets above temp. I have tried replacing the Room thermostat - Drayton model, and the controller Drayton (Invensys) Lifestyle LP522 just replaced today to no avail. I recently replaced also the body of the 3 port motorised valve but not the actuator as the rads were getting hot when the hot water was on. The 3 port valve replacement was a Drayton MA1 like for like swap but I havent swapped the actuator as this appeared to be working ok but I did note though that even when the actuator had been removed from the valve body for a while with the heating off the actuator was getting warm. Its as though its permanently powered even when the heating is off. Is this normal? Its about the only thing I can think of to swap before i admit defeat and call in a plumber. Also of note is that the thermostat doesent make much of a click any more when turning it up ur down past its trigger point it does click but only very quietly. Thanks in advance for any ideas,
