Bit of background first, Question at the end if you don't want the story...
We bought this house at the start of last summer, was built in the 80's and I think still had the original boiler which the previous owner had serviced by BG annually. due to the age of the thing, and a wife that was 7 months pregnant at the time, the first thing I did was fit a carbon monoxide alarm on the landing and some of those card things by the boiler where the spot changes colour. Anyhow, about a week after we had moved in, the pilot light went out and when I went to re-light it, the spot had turned black. Not wanting to take any chances we had someone in to look at the boiler, they were not impressed with what they found and he started to tell me what it needed. I didn't even let him get to the end of his list before I told him to just disconnect the thing from the gas and make safe. Which he did without further comment. I then pulled out the boiler, water cylinder and a whole rats nest of pipework. Money was VERY tight at the time (having just bought the house) so I got a cheap combi boiler (Ideal heating 38KW) and fitted it myself. (Before anyone shouts, I did everything apart from the gas. Got a gas safe registered man in to do that bit and commission the system) Anyhow, the boiler came with built in timer and thermostat, but not a room stat as I thought. So I re-wired in the old dial type stat in the hallway, which is now proving to be problematic, so I am off to get a programmer from screwfix at lunch time today.
So, the questions. :
1- Why does the room stat always seem to be fitted in the hallway? we are never in the hallway so don't much care what the temperature is out there. Does it not make more sense to fit the stat in the living room, or kitchen as these are the most used rooms in the house.
2- Am I OK to fit the stat myself as I wont be messing with anything to do with the gas or burny bits of the system, or do I need to get it signed off by the gas safe man as it does mean opening up the front cover of the boiler.
Thanks in advance.
Thanks in advance.
