i have a sunvic tlx7501 which i have fitted and was told that my 2 wires should be connected as below
red constant - marked C
yellow other wire - marked ON
is this right as the thermostat isnt working, surely the yellow should be in the OFF so that it can switch between constant and off ??
Also, at the moment the heating is on without the thermostat running, where does it gets its temperature command from ??
