Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi, I am about to hire a rubi 1200 manual tile cutter. I need to cut some 1200 x 600 porcelain tiles. They are 10mm thick. Can someone tell me if this equipment will be up to the job. I intend to but a new cutting wheel when I hire it.
It depends on how many & how complicated the cuts are.
Snap cutters will cut porcelain but wet cutters make the job so much easier.
The hire shop will provide new wheels on a not used return basis. They should also advise on how to use their eqpt.
Thanks for the reply. I would rather use a wet cutter. I have one but it is not up to this task. I could not find a hire shop with a wet cutter big enough to cut the tiles on 1200mm length. I will have a word with the hire company.
Hi thanks for the replies. The dry cutter laughed at me when I attempted to cut these tiles. I even had a tiler in my local tile shop have a go at one of the off cuts and he could not cut it. Purchased a wet rubi cutter but found that the blade it came with just chipped the tiles. I bought a 60 pound diamond cutting blade and it worked a treat. I also had to cut slots in the fence on the wet cutter to get the cuts straight as it did not come set up and when I attempted to adjust the fence it only moved about 1mm, with the slots cut I could adjust the position and get the cutting line straight. Got my money back on the hire of the dry cutter though. Spoke to the company that I got the tiles from and they said that you could not cut the tiles with a dry cutter. Lesson learnt..... Ask first and get the correct equipment. Thanks again....
Good - I'm glad things worked out for you.
You did just as any tradesperson would have done - when you encountered a difficulty you dealt with it on the run.
