I want to install an additional double socket in my living room, which will necessitate chasing out and running a cable vertically up the wall and into the loft where I intend to connect it via a junction box to the supply.
Firstly, am I correct in understanding that as long as the cable is routed in a vertical or horizontal safe zone, there's no need to use conduit? As it happens I probably would use conduit anyhow, but I just want to check the regs.
Secondly, is there a minimum height from the floor at which new sockets should be fitted?
Cheers.
Cheers.
