Hi guys, hope you can help me please.
This weekend I intend to install a new radiator in our living room as it currently does not contain any central heating (don't ask me why
). There is already a radiator in our adjoining kitchen and my plan it to tee off from the 15mm flow and return pipes that this is currently connected to. I have also checked that this is the only radiator that runs off this particular branch from the 22mm pipes.
I plan to install the new radiator on the other side of the wall from the kitchen radiator and by far the easiest way to do this would be to bore a suitable size hole straight through the wall to give me new pipes into the living room. Obviously the traditional way would be to take the pipes underneath the floor but I don't fancy digging up the concrete floor in the kitchen.
Is it acceptable to run the new pipes as I have described (ie straight through an internal wall)? Is there anything I should be specifically aware of, for example boring a hole that is a little bit wider than the pipe, any form of insulation round the pipes etc.
Your help is much appreciated as always!
