Hello, I have a [hopefully] simple question.
I wish to mount an LCD TV half way up my living room wall. I want to get the power lead to the TV without having to channel into the walls or build a false wall behind which I can lose the cables. This is because I have just redecorated the room!
The wall onto which the TV is being mounted is an external wall. Could I simply drill through to the outside and run the cable down the outside wall and back in at the appropriate point. Asthetically this would be OK as the external wall is not visible from the garden or front of the house.
The question is: am I allowed to do this? I would use reinforced “outside” cable for the job, and seal the “in” and “out” holes with silicon to prevent bugs getting in. I read somewhere that this approach is not recommended as lightening has a habit of finding external copper wire. Is this true? Is it that different to running a TV aerial down the side of the house (as most houses do)?
I know this is a bit of a “work around” option. Before I do anything I’d like some opinions as to whether it is a sensible thing to consider. I don’t want to introduce any risk safety wise which is why I am calling on the experts to advise.
Thanks in advance,
Ed
Thanks in advance,
Ed
