The CSA will often be embossed into the side of the cable sheath. Have a look.
No, fly lead will do this.So I would need another wire going from the metal box to the earth connection on the socket? Connected to the earth in the armoured cable as well?
Have we not been using that?So in plain English
The earth that is terminated at the bango connection, is connected to earth terminal of the outlet plate, you can get RCD/FCU combos for the termination of the other conductors, one which will be the CPC from the SWA, you did get three core?I need a lead from the metal back box screw to the banjo connection on the gland nothing else. Then wire the armoured cable wires to to rcd one end and fcu in house
