Running UFH pump
1 Dec 2019
The UFH should be up and running tomorrow. I had temporerily hooked it up to check it was all working and all seems good.
I have a large cold area that has sat unheated since the extension began. I assume this will take several days to heat up.
What is the best way to introduce heat into the room? Run it continuously untill it reaches temp (will the pump be ok with this) or run for a few hours in the morning and evening?
From my own experience having UFH in a pug screed I would say your best to just run it 24/7 as if it’s a slab that may well take a long time to be heated.
