I am a little puzzled by the S PLAN wiring diagram (as from Honeywell).
It, unlike the 3 port mid position type, doesn't make 100% sense!!
The cylinder stat 1 terminal is apparently supplied from the HW on at the programmer, and when under temp (60) is should make and put power on to the Brown wire (motor) of the 2 port mv, which then moves across and makes the permanent live (grey wire) close and put power on to the switched live (orange) which in turn make the pump and boiler live.
But the diagram is drawn badly, and according to the way it is drawn, how can 1 make C live, as the switch is the wrong way round.. if you see it you will get me. How can the programmer power (HW on) make the switch SUCK back to the 1 terminal of the cylinder stat?!! shouldn't it be the other way around or is it me looking at it wrong?
And on top of that, the cylinder stat I have says C is the common terminal, 1 is call and 2 is sat. Well, obviously for a 2 port the sat of the cylinder stat is not required, but 1 is call, and according to the honeywell diagram, 1 is the common terminal...
please help me as i am puzzled by this diagram!!!!!
