sadolin and wood filler
24 Apr 2008
UK, Wittering, West Sussex
I have leanto I built about 1997 and coated all the wood in sadolin
a couple of years ago I redid and had to use some wood hardner and a little filler
that has now required re doing and particular the window sill i have completly removed all the rotton wood and hardened and filled with wood filler including all the opened grain
now when i have covered in two coats of sadolin - the wood filler has not taken the colour
any suggestions please
It's a bit like closing the stable door afterwards but you could always have coloured the filler.I've used powdered and tube colourants with two part fillers successfully.
You can also get coloured fillers if you don't fancy mixing your own.
To be completely honest though I'd have spliced in a new cill if it was that bad .
Did you sand the filler before applying the sadolin ? I've found some fillers don't take stain very well if they aren't sanded first two packs like wudfil for instance although sanding will also lighten it as well :?
Another possibility would be to rub it down again and apply a woodstain such as coloron before the sadolin.
Thanks - Yes i did rub the filler all down and the entire sill - its about 4meters long in total and only had minor rot around one area that gets quite wet.
used two grades of paper and used a sander and by hand.
but as the grain was splitting and holding water - I decided this time to all use hardener and filler on a lot of the sill
i think 1 will have to look into the coloron although my other half was quite particular about the colour we used - green
had a product called duckback when first erected and that was too light green
thanks very much for the tip
