Salamander CT50 Shower Pump not switcing off.
21 Dec 2008
Staffordshire
I've just reconnected the pump to a new Aqualisa bar mixer and it runs constantly when connected to power supply, water connections into the pump are same as previous and there are no obvious leaks.
Any suggestions would be greatly appreciated
Thurstk
Usually it’s because the pressure sensor isn’t tripping the supply, have you bled all the air from the pipe work & the pump?
I'm getting a good flow when the shower is running but I will try bleeding all the connections
Thanks for your help
Thurstk
