salamander ct50 shower pump
3 Jan 2011
I have a salamander ct50 pump for my hot water supply .It has been working well now for about 2 years.However, it has started to not turn itself off when you shut off the hot water tap,i can turn it off by it`s plug socket and have been doing this to make it work. Can it be fixed ? does anyone know what to do?
Thanks,my flexi hoses were replaced about 18 months ago because one cracked at the union,so how do i clean it out ? is the switch inside the pump?
remove the outlet flexi and you'll see the flow switch in the black part of the pump.
you can operate them by running a magnet up/down the outside of the black casing.
