Hi All,
Where I live, we've never had decent hot water pressure (so shower from mixer taps is unusable), which I've just put up with since moving in. However, I took off the bath panel yesterday and found a Salamander CT50 pump sat under the bath, which was a surprise!
I'm not sure if this is correct (plumbing isn't a strong point of mine), but the pump is connected directly between the hot water supply (from the tank) and the bath tap. The cold water is not connected, and that end is blanked off.
The wiring is a nightmare and will take some figuring out (it certainly wasn't connected to a live supply), but for testing purposes I connected a mains plug to it and plugged it in to see what happened.
All I got was a slight noise when I turned on the tap and a slight burning smell (which is probably fair enough, it hasn't been used in at least a year), and no difference at all in pressure. The pump body (which I assumed contained the motor) also got very hot - I only had it running for a few seconds.
So, is this unit dead? Or am I missing something? Or is it just badly fitted (given the state of the plumbing here, I wouldn't be surprised)? This is something I've just discovered, so I'm not at all sure what to expect from it....
TIA
Garry
TIA
Garry
