SALUS RT500RF WRONG TEMPERATURE.
6 Feb 2012
Bradford
I have a SALUS RT500RF and the temperature is 3 degrees out. Is there a way I can recalibrate/reset the temperature.
Ian.
How do you come to that conclusion?
Some ( but I dont think Salus ) have an offset adjustment which could be used to correct an inaccurate measurement.
If it really is wrong then it can be a warranty issue and due to be replaced.
Tony
After installing a wood burner in another room borrowed a calibrated thermometer. Then checked the RT500 and noticed 3 degree out.
Ian
Just set it to whatever gives the comfort!
three degrees out if that makes you happy!
