salus rt500rf
22 Oct 2015
Hi I have a RT500rf that is intemitant when signalling to the boiler, I have gone through the jumper reset process.
The receiver next to the boiler seems to click and the light turns a little bit green as if it has recieved the command, but fails to send the signal to the boiler. I don't know if the boiler is at fault or the receiver. Any ideas?
On a side note the boiler which is a greenstar 24i junior, seems to be leaking from the refill valve after it was re-pressurised. The White valve knob is a tight as it will go. Not sure if this is a common problem and easy to fix or a big unusual problem .
Any help greatly appreciated.
The white handle is meant to be removed (and drops a small amount of water) after you've shut the knurled knob, also white -ish. Which are you describing?
The White handle is removed, and the usual drips came out as expected, as this is my second greenstar I at least knew what to expect but two days later it is still dripping, does seem to have slowed a bit, the water coming out is slightly orange in color like watered down iron bru.
