i think the batteries are just to keep the time/date etc in memory if the power fails. obviously, if its soldered in its not designed to be replaced. why do you need to replace it? (lots of power cuts?)
I HAVE THROWN AWAY 3 OF THESE CLOCK THIS WEEK AT £80 EACH BCOS AS THE BATTERY goes FLAT THE CLOCK LOOSES TIME.THIS IS FROM THE MANUF WHO SAY ALL IT NEEDS IS A BATTERY.
If you are talking about the semi industrial three or four pin plug in clocks then the on board batteries on the red faced quartz model are only intended to provide a sustaining power for a short delay of a few hours, not days or weeks.
I do hope that your clocks are not wired backwards or having the supply cut regularly.
They have a limited life of only a few years, say six max. After that the batteries can easily be replaced as a very simple task for anyone capable of soldering electronics components. Its an industry standard NiCad cell but a Li-Ion replacement is probably a better component to use.
FOund this:
"My Q550 timeswitch is losing time. Why?"
"The Q550 timeswitch utilizes a battery and the timing is dependant on the battery voltage. Therefore after approx 8-10 years in operation the timing varies as the battery voltages decreases. Replacing the battery would resolve the problem. For spare batteries please contact either of the following spares agents:- Heating Control Services Contact: Eric Messenger Tel no: 01922 634503 BJH Electrical Contact: Mr Martin Tel no: 01277 227116"
