Samsung Smart TV
15 Nov 2005
South
Cook Islands
Anyone using a USB hard drive as a programme recorder on one?
Yes
Just make sure you 'format' the drive through the samsung menu after you first attach it in order to activate the USB record ability of the TV.
oh, it works, but suddenly, although it would record both TV and radio programs, it was unable to open and playback any radio progs.
I wasted a long time with Samsung customer support, including remote access and screenshots to take to their tech spec, who passed back the message that my hard drive must be failing and I should buy a hard PVR instead. Load of cobblers, because all the TV progs still work, and the "info" on the radio progs shows their title, run time, date etc.
Samsung 'smart' TV's do seem a bit odd.
I've found problems streaming certain types of files whilst they play ok from a USB stick or Hard Drive and vice versa.
Sometimes after I had played a certain type file (MP4) via USB it then suddenly worked streaming!
So it might be worth transferring the file to a USB stick and see what happens.
