sand after undercoat?
19 Sep 2006
is it worth sanding after the undercoat has dried with fine paper or is it ok to just go ahead and apply gloss? ie - will it make much difference in the finish? thanks
if you run your hand over the undercoat,you will probably find bits in it.i always rub down undercoat.it gives it a crystal finish.
Always rub it down It's the secret to a good job.
Used sand paper 240 grade this afternoon came out nice, :) thanks
Did the hall way last month but didnt sand down and the difference is actuallt visible looking closely
