Sand between top coats even for matt paint?
8 Sep 2010
South West Wales
Hi all
Just a quickie..... I know it is generally seen as good practice to sand between coats of paint, but I wanted to check whether this is still necessary for matt paints. I'm using this stuff on my exterior wooden windows:
http://eico.co.uk/products/eico-alterior-matt-2-5l/
Hoping to get the job finished ASAP with the weather turning. So if I can skip the sanding and clean up between the two top coats that will help a lot. But if it's needed, it's needed.... So thought I'd best check with you guys.
Cheers
Max
As a rule of thumb it is not neccessary to sand between coats provided that the previous coat has not fully cured.
With waterbased paints you are looking at up to 3 days, unless the makers suggest otherwise.
It surely depends on the quality of the original preparation, the state of the wood/metal underneath and whether the surface feels smooth to the touch before each top coat.
Hi EB
the OP was asking about sanding between top coats, I assumed that he had already prep'd prior to painting.
It also depends how good you want it to look! But yes, proberbly overkill.
