Hi all
Just a quickie..... I know it is generally seen as good practice to sand between coats of paint, but I wanted to check whether this is still necessary for matt paints. I'm using this stuff on my exterior wooden windows:
http://eico.co.uk/products/eico-alterior-matt-2-5l/
Hoping to get the job finished ASAP with the weather turning. So if I can skip the sanding and clean up between the two top coats that will help a lot. But if it's needed, it's needed.... So thought I'd best check with you guys.
Cheers
Max
Cheers
Max
