Sash window painting
3 Feb 2026
I need to repaint the interior of my sash windows but just want to check the steps.
Ive given them a good clean but still need to sand then down and remove loose paint.
Once that done should I use wood filler or something else to fill the gaps between the window and wood? Or use putty?
Then I suppose prime bare wood then paint?
2 pack wood filler would work but be tidy..
Maybe use masking tape to protect area you don't want to get it on and to stop scratching when you sand.
Sandpaper can scratch glass and plastic and many things so masking is a basic protector.
Gaps that move but are narrow caulk is good.
So sand a scrap all loose parts, then use 2 part wood filler for the gaps and use tape to protect glass?
Should i use a bit of wood hardener first before using the filler?
Sand the loose paint and timber off. Yes to wood hardener. Fill the gaps with flexible, paintable filler. Allow to dry then paint using your preferred system.
In the older days the gaps would have been filled with linseed oil putty - but that does harden over time.
