Satalite cable to booster amplifier see the photos please
5 Nov 2006
London
I going to try to connet 6 tv on my house to my satellite dish instead to my terrestrial tv antena
I was wondering if some one can gime me a hand to connect this tv amplifier
http://technical.philex.com/downloads/rf/SLXB.pdf
to my satellite tv
see the photos View media item 7057
frontal
side
View media item 7058connections
The first cable is the one that goes to my satellite receiver the second is teh one from the LNB
View media item 7059
The booster has a UHF connetion. Which cable shall i put there?
Many thanks, for your time.
Do NOT do this outside up where your dish is.
I have this 6 way amp in the back of a cupboard, used it in my last house.
It is for INDOOR use only.
You simply put it inline with the TV aerial cable - into the UHF socket marked then take your outputs to the 6 other TV's in separate rooms.
Although I'm not sure its going to work for you on the satellite dish as ISTR the frequencies are a lot higher although that amp does pass the signals from out of the satellite box and works with a magic eye.
Another thing is, if your wanting to split it 6 ways, you will need 6 receivers.
What are you planning?
6 freesat receivers or 1 receiver and 6 tv's watching the same channel?
