After at least 30 years service the 2 port 5 wire Satchwell Minivalv on my CH is getting temperamental. The valve itself still turns freely. Naturally I'd prefer to just replace the actuator. Would anyone know if the Sunvic SM5203 is a direct replacement. I'm thinking particularly does it fit directly onto the existing mounting plate and engage the tongue of the valve. The plastic body looks a little different and it looks like it bolts through the mounting plate whereas the original has studs in the actuator that pass through the mounting plate for nuts. Mounting holes appear to be in the same corners though.
I'm fairly certain the valve was installed early 70's so it has lasted amazingly well.
If anyone knows if it's a direct replacement be grateful to hear. Thanks.
