Saw cutter says 20mm bore. All discs 22mm?
30 May 2021
Hi all,
I am getting a wet saw cutter to cut some porcelain slabs for my patio,
The item description says 110mm disc with 20mm bore
All the blades I'm finding are 22mm bore, is this suitable for the item. Or am I meant to get a 20mm disc bore from somewhere?
ok,
they do have some 20mm bore - if you look down to frequently bought together
you may be able to get a reducing ring, not sure how well that would work on that machine
https://www.amazon.co.uk/Loops-Diamond-Cutting-Wheel-Marble-Porcelain/dp/B07XVQ5X71/ref=sr_1_5?crid=20KIH6Y4BC436&keywords=wet+stone+cutter&qid=1652531470&s=diy&sprefix=wet+stone+cutter,diy,56&sr=1-5
you may find some of the cheap blades will chip out the tile
Best i found was using the table saw for tiles - worked much better then my angle grinder
But i guess it depends on what you are cutting and where they are to be fitted
An Amazon review says the following
"I also bought a reducing bush so I could use 115mm 22mm bore blades : "Spectrum JRB22-20 22.2mm - 20mm Reducing Bush" ebay item 391909146708"
For what it is worth, I like Spectrum diamond blades. I wouldn't want to use a Silverline one.
If you are willing to pay more... Festool sell a (plunge) dry diamond angle grinder that runs on their saw tracks and connects to a dust extractor.
I am considering buying one. I have a customer that has tiles sitting at 45 degrees on a path that runs between two water filled rills. I want to ensure that I can cut them back in a "perfectly" straight line, and additionally cut them at about 13 degrees.
