Scalding Hot Water
  • Thread starter Thread starter BF
  • Start date Start date
BF
26 Oct 2003
London
I've got a problem with my CH so have the immersion switched on to heat the water.
Since doing so my hot water is absolutely scalding even though the temperature according to the setting is 45C.
Does this sound right at 45C or could the thermometer or whatever it is be faulty?
When the CH is working the water is hot much not dangerously so.
Likely the thermostat on immersion is faulty. I would recommend you dont use the immersion until this is fixed. New stats can be bought seperately, you dont need a complete new immersion.
Please be aware, immersions can boil the cylinder contents if the stat is faulty. There was a fatality in recent years when an immersion boiled the cylinder contents, which in turn heated the cold storage tank in the loft above. Eventually this became so hot, it collapsed, showering a baby asleep below with scalding water.
N.B. Hot water should be heated to 60C to kill off any possible Legionella bacteria, 45C is too low.
Thanks for your reply.
It must be faulty as this water is burning if just slightly touched. I`ll get it checked out and turn off as advised.
Thanks.
