Scantronic 9448+ inputs
17 Nov 2009
Ayrshire
Hi. My trusty 9200 alarm panel now seems to have finally bitten the dust. I was looking at replacing it with a 9448+ panel. However, going by the rather brief diagram, the zone and e/e inputs seem to require the addition of an in-line resistor. I just put the wires from the PIRs and door contacts straight into the 9200 panel at the moment. Does this mean that I need to find and solder in some resistors to all the inputs for the 9448?
Thanks :confused:
The 9448+ doesnt use resistors, the wiring and diagrams should be virtually identical.
Thanks Denford1. I've got a wiring example for the 9448+ and although there is nothing shown for the zones there is a resistor shown on the E/E contact. Perhaps there is some difference between the 9448+ and 9448EUR models? Are you sure I don't need any?
Also, reading through the forum, and looking at the diagram, My Bell system looks like SAB. The strobe seems to be permanently wired to the negative with a relay contact suppying the positive. The new diagram shows the strobe permanently wired to the positive with a strobe output. So I'm wondering now if this is compatible?
Any suggestions?
... then you have a 9448ES NOT a 9448+
The resistor is needed
Nope. Just looking at the different model names and a bit confused.
So now someone says I need a resistor on the inputs and someone says I don't!
wait till you get onto the bellbox trigger monitoring ..............
9448 = NO RESISTOR in E/E circuit
9448+ = NO RESISTOR in E/E circuit
9448ES = RESISTOR in E/E circuit
someone
9448ES
"Raccordements des contacts magnétiques
La figure 13 décrit les raccordements, lorsqu’il existe un contact magnétique par zone.
Utiliser un câble à 4 conducteurs pour les connexions des boucles d’autoprotection et
d’alarme. Il est à noter que le contact reed est raccordé entre les vis en métal plaqué
(bornes repérées en noir sur le schéma)."
no mention of resistors .................
All clear now.
It has been suggested that I fit a Scantronic 9651EN-00 which has the option for resistors. Does anyone know where I can find a wiring diagram for the connections? Also, I want to use the existing SAB bell housing and as Atilla points out this may be a matter of concern!
All clear now.
your bell will be fine - I was taking the proverbial
