Hello
My alarm panel has developed a fault-the internal sounder has stopped working and the final exit sensor on the front door appears to be at fault when we try and activate the alarm
basically it says their is a fault with the sensor (a magnetic one built into the door)
I have entered engineer mode and exited it which I thought ran some diagnostics but it simply leaves engineer mode with no problem. I am going to open the panel and check the wiring connections are still okay and also check the internal sounder works by connecting it straight to another source
Any ideas what else I should do to test it?
many thanks
Yoghurt
many thanks
Yoghurt
