The long since disappeared installer ran cables from 2 door switches and a pir in my attached garage up through the cavity at an angle coming out through the floorboards in a fitted wardrobe and up to the loft 3ft out from the wall, across the loft then down through the airing cupboard, then clipped down the side of the stairs to the panel.
I have removed the wardrobe and I am about to remove the airing cupboard
so I have to rewire this mess.
I have already put a 12 core and an 8 core from the garage under the floor upstairs to the landing long enough to go to the panel, this just leaves the bell box wiring.
I would like to drop a cable from the loft area to the garage (an easy out of sight run) and use the 12 core for the door switches and pir leaving me 4 spare cores, then use the 8 core cable for the bell.
I would connect them all in a plastic adaptable box using crimp connectors.
Is this acceptable?
I assume that the bell is going to sound all the time while Im connecting the cables even after I enter my own user code with the panel open unless I remove the battery?
Also I have a spare 2nd hand 9448 panel I bought "just in case" some time ago, I dont have the installer manual and of course I dont know the code, can anyone help with this? I can take a pic of it to prove I have it if needed.
Is this acceptable?
