I have been asked to quote for a new boiler at a local primary school.
At present there is a Glowworm economy plus 80f .
I don't hold any commercial qualifications but as I understand it I'm allowed to work on it as there is a isolation/ lever valve between main gas pipework ( 2" screwed steel) and the appliance.
Question is , do I need to fit a emergency knock off/ isolation switch and solenoid?
If so where is best place to fit switch? Presumably outside the room which contains the boiler?
Boiler will feed two tiny rads and two wall mounted high level fan blower type things
