Scorched grass
5 Jan 2004
I committed a sin, I didnt water the fertiliser into my grass properly and now have some scorched areas. Will I need to reseed or will it come back to being green!!?? :?
Depends, what sort of fertiliser was it? If it was an ammonia based fertiliser, probably not.
Tip: Sprinkle a small amount of Sulphate of Ammonia onto a dandelion crown in a lawn, and burn it clean out! You'll have to re-seed, but the dandy will be gone!
What you'll probably have to do is scarify it a bit, then re-seed, otherwise you run the risk of weed seeds or moss taking over the affected area.
I am no gardener, but this time 2 yrs back I had the same problem.
Broke up the surface and seeded the patches in a layer of compost, it worked a treat, to my surprise !
Cannot normally see the joins today ... The different grasses become noticeable in length only, after a lengthy gap in mowing.
P
Thats what I thought I would have to do , but was hoping Not to!! At least its not the whole lawn, its 65ft long!!
It was a typing error, its actually 65metres!! Enjoyable but labour intensive!!
