I'm constructing a wooden fence to attach to the side of a concrete terrace but am uncertain as to the size screws / bolts required. The posts are 9cm by 9cm, and 2.4 metres in length. I was planning to cut them down to 1.5 metres, giving 1.1 metres of post from 'floor / terrace' level up, with 40cm then available to drill through for fixings to the wall. The fence itself will then have two horizontal bars on it, hence not too much wind resistance.
Questions:
1. I've identified 165mm long screws which with them being countersunk, would give me approx. 7cm of screw actually in the concrete. I was planning on using three screws per post.
2. Is 40cm enough or will the post be more rigid if I allowed say 1m for screw fixings, hence being able to space the 3 screws out more?
Appreciate any help on this.
Questions:
