Screwing down old square-edge floorboards
25 Nov 2006
London
Hello.
Am looking for a steer on the screws I'll need for replacing old 19mm square-edge pine floorboards onto the joists.
The boards are going to be sanded so will need to be 2-3mm countersunk. I'd quite like small heads but not at the expense of them pulling through.
I started with some Turbo TX 4mm x 50mm because I thought they'd be better than cross-headed ones but got a bit nervous when the heads on a couple of them got mangled when I tried to remove them.
Looking at Toolstation there's Floor Tite Tri Lock Pozi Screw and Spax Wirox but only in 60mm so probably too big. Screwfix do one called Optimaxx 4 x 50mm
Not sure if I'm over-thinking it but tips on what to look out for would be good. Thanks!
The screws should be twice the thickness of the board plus the board depth so 60mm, in practice you can get away with less. I use the Spax wood screws because they are the best imo.
Thanks. Most of the reviews talked about chipboard, so I wasn't sure. Is it any Spax or a specific one?
Just their standard wood screw. If you are concerned about appearance use nails
