Hi.
I am about to undertake a shower installation, and in doing so need to erect some studding to hide pipework etc. I was going to do this by screwing/plugging battons onto the walls against which the shower will be positioned.
My concern is that these walls were recently re-plastered - with sand/cement/waterprooofer mix - due to hygroscopic salts causing damp in the plaster. Would drilling and plugging into these walls cause problems and reduce the damp protection offered by the re-plastering?
If so, is there anyway of screwing into these walls without causing a problem? I was considering injecting a waterproof mastic into the holes before and after the plug is inserted. I feel this method may not work however due to the mechanics of the masonary plug disrupting the mastic.
