I am making a stair case with wood planks supported on two steel stringers There are two holes already drilled in the steel support. I need to be able to line up the plank and know where to drill the holes for the bolts to exactly meet the holes in the steel support.
The problem is two sides of the plank are wany edge so no straight edge to measure from and the stairs are free standing so not resting against the wall to give a measuring point. They are 35mm thick by approx 230 wide by 74mm length
The only suggested way is to mark the rings of the holes from underneath the plank then mark the centre of those holes and drill tnrough the wood from the underside.
Is there a simpler or more reliable way of lining the plank to holes for drilling. Could it be done easier in a joinery shop if I can find one ?
